Ir para o conteúdo principal
JD Razor 2000 Quick-Release Lever Replacement
O que você precisa
  1. JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: passo 1, imagem 1 %32 JD Razor 2000 Quick-Release Lever Replacement, Unlocking the Lever: passo 1, imagem 2 %32
    • Unlock the quick-release lever by turning the lever from a tightened position.
  2. JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: passo 2, imagem 1 %32 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: passo 2, imagem 2 %32 JD Razor 2000 Quick-Release Lever Replacement, Loosening the Screw: passo 2, imagem 3 %32
    • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
    • Be sure to fasten the opposite side of the screw before unscrewing.
    • Remove the screw and note the order of the parts for reassembly.
  3. JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: passo 3, imagem 1 %32 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: passo 3, imagem 2 %32 JD Razor 2000 Quick-Release Lever Replacement, Removing the Latch: passo 3, imagem 3 %32
    • Turn the quick-release lever over to reveal an 8mm screw.
    • Use the Phillips #2 screw driver to remove the screw.
    • After removing the screw, the circular latch will be detachable.
Conclusão
Shane
Membro desde: 10/18/14
384 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-46, Amido Fall 2014 Membro de Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 2,535
