Ir para o conteúdo principal
JD Razor 2000 Handle Bar Replacement
O que você precisa
  1. JD Razor 2000 Handle Bar Replacement, Pulling Out the String: passo 1, imagem 1 %32 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: passo 1, imagem 2 %32 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: passo 1, imagem 3 %32
    • Firmly hold the handle bar in place.
    • Grab with one hand the black removable tip of the handle bar and pull it out.
    • Pull out the end of the tied string through the removable tip.
  2. JD Razor 2000 Handle Bar Replacement, Untying the Knot: passo 2, imagem 1 %32 JD Razor 2000 Handle Bar Replacement, Untying the Knot: passo 2, imagem 2 %32
    • Untie the knot at the end of the string.
    • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
  3. JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: passo 3, imagem 1 %32 JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: passo 3, imagem 2 %32
    • Press down firmly on the golden fastening button located on the handle bar being replaced.
    • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
    • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
Conclusão
Kevin Church
Membro desde: 10/16/14
297 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-46, Amido Fall 2014 Membro de Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
Membros da 4
Autoria de 16 guias
Um comentário
Why is the stretchable string for?
dantotford - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 2,031
