Ir para o conteúdo principal
JD Razor 2000 Front Wheel Replacement
O que você precisa
  1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: passo 1, imagem 1 %32 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: passo 1, imagem 2 %32 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: passo 1, imagem 3 %32
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: passo 2, imagem 1 %32
    • Grip the bottom of the wheel and gently slide it out.
Conclusão
Kaylan Naicker
Membro desde: 10/14/14
255 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-46, Amido Fall 2014 Membro de Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 944
