Ir para o conteúdo principal
JBL Xtreme Speaker Replacement
O que você precisa
  1. JBL Xtreme Speaker Replacement, Cover: passo 1, imagem 1 %32
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Speaker Replacement: passo 2, imagem 1 %32 JBL Xtreme Speaker Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Speaker Replacement: passo 3, imagem 1 %32 JBL Xtreme Speaker Replacement: passo 3, imagem 2 %32
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Speaker Replacement, Bass Radiator: passo 4, imagem 1 %32 JBL Xtreme Speaker Replacement, Bass Radiator: passo 4, imagem 2 %32 JBL Xtreme Speaker Replacement, Bass Radiator: passo 4, imagem 3 %32
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Speaker Replacement: passo 5, imagem 1 %32 JBL Xtreme Speaker Replacement: passo 5, imagem 2 %32 JBL Xtreme Speaker Replacement: passo 5, imagem 3 %32
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
  6. JBL Xtreme Speaker Replacement, Speaker: passo 6, imagem 1 %32 JBL Xtreme Speaker Replacement, Speaker: passo 6, imagem 2 %32
    • With the radiators removed, locate the ribbon cable indicated in the image.
    • Gently unplug the cable from the motherbord.
  7. JBL Xtreme Speaker Replacement: passo 7, imagem 1 %32 JBL Xtreme Speaker Replacement: passo 7, imagem 2 %32 JBL Xtreme Speaker Replacement: passo 7, imagem 3 %32
    • First, unscrew the eight 12.93mm Phillips head screws indicated in red. These screws hold the two primary speakers in place.
    • Next, remove the four 9.75mm Phillips head screws for the two smaller speakers indicated in blue and the speakers should lift out with little effort.
    • All speakers are connected via the single cable highlighted in the previous step.
Conclusão
15 outras pessoas executaram este guia.
Benny Huynh
Membro desde: 02/15/17
1.953 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-1, Sullivan Spring 2017 Membro de USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
Membros da 4
Autoria de 27 guias
11 comentários
My speaker won't hold a charge for more then 2 hours? Why is that thanks
Gil Trujillo - Responder
where can i buy the speaker of jbl xtreme?
Jeff Cancino - Responder
Where can I get replacement speakers for my JBL?
Luis Baca - Responder
Where can I get s replacement speaker
etesme -
where can I get parts to fix the speaker?
Dave - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 44
Últimos 30 dias: 169
Duração total: 30,134
