Ir para o conteúdo principal
JBL Xtreme Cover Disassembly
O que você precisa
  1. JBL Xtreme Cover Disassembly, Cover: passo 1, imagem 1 %32
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Cover Disassembly: passo 2, imagem 1 %32 JBL Xtreme Cover Disassembly: passo 2, imagem 2 %32
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Cover Disassembly: passo 3, imagem 1 %32 JBL Xtreme Cover Disassembly: passo 3, imagem 2 %32
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Conclusão
14 outras pessoas executaram este guia.
Benny Huynh
Membro desde: 02/15/17
1.953 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-1, Sullivan Spring 2017 Membro de USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
Membros da 4
Autoria de 27 guias
5 comentários
Can you fix my cover on speaker
c_pg08 - Responder
where can I find a new cover for xtreme 2, if possible in black?
vale0501 - Responder
If you find a place to buy a cover let me know
abjayaman -
you forgot about 2 screws
Enescu Catalin - Responder
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
megakacper11 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 57
Últimos 30 dias: 210
Duração total: 31,006
