Ir para o conteúdo principal
JBL Xtreme Bass Radiator Replacement
O que você precisa
  1. JBL Xtreme Bass Radiator Replacement, Cover: passo 1, imagem 1 %32
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Bass Radiator Replacement: passo 2, imagem 1 %32 JBL Xtreme Bass Radiator Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Bass Radiator Replacement: passo 3, imagem 1 %32 JBL Xtreme Bass Radiator Replacement: passo 3, imagem 2 %32
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Bass Radiator Replacement, Bass Radiator: passo 4, imagem 1 %32 JBL Xtreme Bass Radiator Replacement, Bass Radiator: passo 4, imagem 2 %32 JBL Xtreme Bass Radiator Replacement, Bass Radiator: passo 4, imagem 3 %32
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Bass Radiator Replacement: passo 5, imagem 1 %32 JBL Xtreme Bass Radiator Replacement: passo 5, imagem 2 %32 JBL Xtreme Bass Radiator Replacement: passo 5, imagem 3 %32
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
Conclusão
12 outras pessoas executaram este guia.
Benny Huynh
Membro desde: 02/15/17
1.953 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-1, Sullivan Spring 2017 Membro de USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
Membros da 4
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 107
Duração total: 20,831
