Ir para o conteúdo principal
JBL Xtreme Akku austauschen high power
O que você precisa
  1. JBL Xtreme Akku austauschen high power, Akku: passo 1, imagem 1 %32
    • 8,4 V externer Akku für JBL Extreme
  2. JBL Xtreme Akku austauschen high power: passo 2, imagem 1 %32
    • Gehäuse aufschrauben dazu die Hülle entfernen.
  3. JBL Xtreme Akku austauschen high power: passo 3, imagem 1 %32
    • Akkufach mit 8 Schrauben lösen. Akku entfernen. Loch bohren. Löcher wegen der Luftdichtigkeit mit Heißkleber verschließen.
  4. JBL Xtreme Akku austauschen high power: passo 4, imagem 1 %32 JBL Xtreme Akku austauschen high power: passo 4, imagem 2 %32
    • Anschlüsser + und - verlöten. Zur Stromversogung einen DC Hohlbuchse 5.5 x 2.1 verwenden. Kabelenden Isolieren.
  5. JBL Xtreme Akku austauschen high power: passo 5, imagem 1 %32
    • Akku 8,4 Volt. 13200mAh 8,4V Akku Batterie-Pack Ladegeraet für Fahrradlampe-XML-T6
  6. JBL Xtreme Akku austauschen high power: passo 6, imagem 1 %32
    • Solarstorm 2S2P 18650 Battery Case.
    • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
    • + 5V USB ON/OFF Button
Conclusão
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Bert
Membro desde: 06/27/17
217 Reputação
Autoria de 1 guia
6 comentários
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - Responder
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - Responder
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - Responder
Hi.
See the comment higher.
Martin Kubica
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
fixit4 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 39
Últimos 30 dias: 136
Duração total: 28,306
