Ir para o conteúdo principal
JBL Xtreme 3 Speaker Replacement
O que você precisa
  1. JBL Xtreme 3 Speaker Replacement, Exterior Speaker Shell Cover: passo 1, imagem 1 %32
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 Speaker Replacement: passo 2, imagem 1 %32
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 Speaker Replacement: passo 3, imagem 1 %32 JBL Xtreme 3 Speaker Replacement: passo 3, imagem 2 %32
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
  4. JBL Xtreme 3 Speaker Replacement, Speaker: passo 4, imagem 1 %32
    • Once the shell has been romved use a #2 phillip's screwdriver to remove the 8 screws on the two speaker.
    • Repeats the first step for the second speaker.
  5. JBL Xtreme 3 Speaker Replacement: passo 5, imagem 1 %32
    • Use a spudger to prop speaker out.
  6. JBL Xtreme 3 Speaker Replacement: passo 6, imagem 1 %32
    • Carefully squeeze the clip on each cable and pull it to disconnect the speaker.
    • Replace the speaker.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 70
Duração total: 1,610
