Ir para o conteúdo principal
JBL Xtreme 3 Battery Replacement
O que você precisa
  1. JBL Xtreme 3 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
    • Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
    • Use your hands to finish removing the outer case of the device.
  2. JBL Xtreme 3 Battery Replacement: passo 2, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the two 10 mm screws.
  3. JBL Xtreme 3 Battery Replacement: passo 3, imagem 1 %32 JBL Xtreme 3 Battery Replacement: passo 3, imagem 2 %32
    • Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
    • Remove the speaker from the shell.
  4. JBL Xtreme 3 Battery Replacement: passo 4, imagem 1 %32 JBL Xtreme 3 Battery Replacement: passo 4, imagem 2 %32
    • Turn the device so that the control buttons are facing down.
    • Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
    • Carefully remove the panel.
  5. JBL Xtreme 3 Battery Replacement: passo 5, imagem 1 %32 JBL Xtreme 3 Battery Replacement: passo 5, imagem 2 %32
    • The battery is connected to a cable. Use gentle force.
    • Use the spudger to carefully pry the battery out.
  6. JBL Xtreme 3 Battery Replacement: passo 6, imagem 1 %32 JBL Xtreme 3 Battery Replacement: passo 6, imagem 2 %32 JBL Xtreme 3 Battery Replacement: passo 6, imagem 3 %32
    • Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
    • Plug in the replacement.
    • Make sure the new battery is secure. Turn on the device to ensure that the battery is connected properly.
Conclusão
5 outras pessoas executaram este guia.
Um comentário
Great guide! Thank you!
dam damo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 53
Últimos 30 dias: 212
Duração total: 2,943
