Introdução
If you’re JBL Xtreme 2's speaker sounds disoriented or is making no sound, use this guide to replace the speaker(s). The speakers inside are used to make the bass for the experience of listening to music. When a speaker is damaged you will hear distorted music or none at all.
Before beginning make sure to power off the speaker and disconnect from any external power source.
O que você precisa
Use a spudger or other prying tool to gently pry open the middle section of the speaker.
