Ir para o conteúdo principal
JBL Tune 710BT Ear Pad Cushion Replacement
O que você precisa
  1. JBL Tune 710BT Ear Pad Cushion Replacement, Ear Pad Cushion: passo 1, imagem 1 %32
    • Gently grasp the edge of the ear cushion and pull it away from the earcup.
    • The cushion is usually snapped or clipped into place and should come off with moderate force. If the cushions are glued, carefully pry them away from the earcup, either with hands or gently with a tool.
  2. JBL Tune 710BT Ear Pad Cushion Replacement: passo 2, imagem 1 %32
    • Align the new ear cushion with the earcup.
    • There should be notches or tabs that align with corresponding slots on the earcup.
    • Press the cushion into place, ensuring that it is securely fastened all around the earcup.
    • Once attached, gently pull around the edges of the cushion to ensure it is securely fastened and there are no loose parts.
Conclusão
With the new ear cushions installed, your JBL Tune 710BT headphones should feel more comfortable and provide better sound isolation. This simple upgrade can significantly enhance your audio experience.
Amber Hooda
Membro desde: 03/18/24
90 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-1, Konn Spring 2024 Membro de UMass Dartmouth, Team 2-1, Konn Spring 2024
UMASSD-KONN-S24S2G1
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 21
Últimos 30 dias: 21
Duração total: 36
