Ir para o conteúdo principal
JBL Spyro/Spot Partial Disassembly
O que você precisa
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: passo 1, imagem 1 %32
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: passo 2, imagem 1 %32
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: passo 3, imagem 1 %32
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
Conclusão
17 outras pessoas executaram este guia.
Ryan McLeod
Membro desde: 05/22/10
606 Reputação
Autoria de 2 guias
11 comentários
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - Responder
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - Responder
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 46
Últimos 30 dias: 106
Duração total: 13,023
