Introdução
There are four speakers located on the base of the JBL Pulse 3 under the speaker grill.
O que você precisa
Lay the JBL Pulse 3 on its side as shown in the picture.
Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
Ca I Specifically buy the top ring
Opening is not as simple as demonstrated in Step 6. I have followed everything through, am I missing something?
Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
This phase could be difficult. Try to “twist” the speaker to have a little gap between both parts and insert gently a screwdriver or opening toile to spread the gap.
Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
Pull the LED light display off of the JBL Pulse 3 base.
Use tweezers to pull the five connections off of the LED light display.
up to step 13, the battery replacement steps are the same.
From step 14 the steps change.
Very good instructions for changing the battery in the jbl pulse 3 can be found here:
https://www.youtube.com/watch?v=MpznDgxg... -
Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
Pull the rest of the motherboard out from the LED light display.
Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
Hi Guys! Thanks a lot for the tutorial, but anyone knows where THIS BLACK WIRE IS CONNECTED at the base of the speaker? I accidentally remove it..
Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
Note: To finish replacing the speaker, you must solder both wires back on to the new speaker.
