Introdução
If there is a sense of general unresponsiveness or faulty functionality in your JBL Pulse 2 speaker, you may need to replace the motherboard. Replacing the motherboard ensures that your device works at peak capacity.
O que você precisa
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
Ferramenta utilizada nesse passo:Tweezers$3.99
Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
Manually remove the LED strips from the outside of the white plastic casing.
3 outras pessoas executaram este guia.
