Introdução
If you are experiencing any difficulties using the buttons on your JBL Pulse 2, you may need to replace the button circuit board.
O que você precisa
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
3 outras pessoas executaram este guia.
