Introdução
First, the device will need to be cracked open. After, you will remove the damaged speakers and replace them with new, working speakers.
O que você precisa
Turn the device upside down so that the three rubber pads are facing up.
To reassemble your device, follow these directions in reverse order.
5 outras pessoas executaram este guia.
8 comentários
Where can I buy the replacement speaker?
I join Gןilberto question,can someone attach a link to replacement speakers or tell what is the p/n of the speakers ?
Thanks !
little bit late i just order it after 2 years searching
Do these work as original driver are 8 ohm?
