Ir para o conteúdo principal
JBL Flip 4 Shell Replacement
O que você precisa
  1. JBL Flip 4 Shell Replacement, Shell: passo 1, imagem 1 %32 JBL Flip 4 Shell Replacement, Shell: passo 1, imagem 2 %32 JBL Flip 4 Shell Replacement, Shell: passo 1, imagem 3 %32
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
  2. JBL Flip 4 Shell Replacement: passo 2, imagem 1 %32 JBL Flip 4 Shell Replacement: passo 2, imagem 2 %32 JBL Flip 4 Shell Replacement: passo 2, imagem 3 %32
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
Conclusão
7 outras pessoas executaram este guia.
Philip Pang
Membro desde: 10/08/18
1.270 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S4-G3, White Fall 2018 Membro de Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
Membros da 4
Autoria de 36 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 44
Últimos 30 dias: 191
Duração total: 13,720
