Ir para o conteúdo principal
JBL Flip 4 Front Active Speaker Replacement
O que você precisa
  1. JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: passo 1, imagem 1 %32 JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: passo 1, imagem 2 %32 JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: passo 1, imagem 3 %32
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, it will make a snapping sound.
    • Pull off the cover with your thumbs.
  2. JBL Flip 4 Front Active Speaker Replacement: passo 2, imagem 1 %32
    • Remove all four 10 mm JIS #1 screws around the damaged front active speaker.
    • The speakers are strong magnets. Keep metal tools or other magnetic objects away from the driver.
  3. JBL Flip 4 Front Active Speaker Replacement: passo 3, imagem 1 %32 JBL Flip 4 Front Active Speaker Replacement: passo 3, imagem 2 %32 JBL Flip 4 Front Active Speaker Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool under the unscrewed front active speaker.
    • Pry off the front active speaker with the opening tool.
    • Do not yank the front active speaker out. It is connected to wires within the device.
  4. JBL Flip 4 Front Active Speaker Replacement: passo 4, imagem 1 %32
    • Cut the red, white, and black wires connected to the speaker using wire cutters.
    • You will need to re-solder these wires when installing the new speaker.
Conclusão
14 outras pessoas executaram este guia.
Ryan Whitlock
Membro desde: 10/08/18
2.078 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S4-G3, White Fall 2018 Membro de Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
Membros da 4
Autoria de 36 guias
16 comentários
And where can you find the replacement part? I cannot find a replacement speaker on the internet…
Sven Meirsman - Responder
Exactly, what is the part number for the internal speaker?
Dan The Menace Brenes - Responder
The part number is: psp00018001
Johankat -
If the magnet comes loose from the speaker how do you get it back on?
Andrew Sumahit - Responder
Replace the entire speaker.
Magnet realignment is crucial for the speaker to perform properly.
Johankat -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 117
Últimos 30 dias: 404
Duração total: 34,469
