Ir para o conteúdo principal
JBL Flip 3 Side Passive Driver Replacement
O que você precisa
  1. JBL Flip 3 Side Passive Driver Replacement, Side Passive Driver: passo 1, imagem 1 %32
    • Remove the plastic outer housing using your hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Side Passive Driver Replacement: passo 2, imagem 1 %32
    • Use your hands to carefully remove the outer frame to expose the inner components of the speaker.
  3. JBL Flip 3 Side Passive Driver Replacement: passo 3, imagem 1 %32
    • Go around the outer edge of the side passive driver with a screwdriver to remove the seven 8.9mm Phillips #00 screws from both sides of the device. Make sure to set the screws aside somewhere they won’t get lost.
  4. JBL Flip 3 Side Passive Driver Replacement: passo 4, imagem 1 %32 JBL Flip 3 Side Passive Driver Replacement: passo 4, imagem 2 %32
    • Remove the side passive driver.
Conclusão
5 outras pessoas executaram este guia.
College Student
Membro desde: 02/22/17
3.512 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G2, Leahy Spring 2017 Membro de USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
Membros da 5
Autoria de 18 guias
2 comentários
What the fock?!?!? Ohhh, you basterds. I see what kind of game you're playing. I'm coming to get ya'. I'm gonna track you down, so help me God. I won't rest until I feel the warm, sticky blood of this author, and anybody that looks like him!! I will have my vengeance! I shall reign down upon him like a…(ding!) Ooohh! My toaster pastries!
Johnny Johnson - Responder
Do you know what would be great? If we could source these diaphrams, or speakers, or whatever is being shown here to replace. They are nearly impossible to source!!
Muhip Tuna Meti - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 39
Duração total: 10,877
