Ir para o conteúdo principal
JBL Everest Elite 300 Headband Cushion Replacement
O que você precisa
  1. JBL Everest Elite 300 Headband Cushion Replacement, Headband Cushion: passo 1, imagem 1 %32
    • Extend the headphone.
  2. JBL Everest Elite 300 Headband Cushion Replacement: passo 2, imagem 1 %32 JBL Everest Elite 300 Headband Cushion Replacement: passo 2, imagem 2 %32 JBL Everest Elite 300 Headband Cushion Replacement: passo 2, imagem 3 %32
    • Bend the hinge slightly, then remove the two .5 mm screws with a Phillips #000 screwdriver.
    • This will be repeated on both sides.
  3. JBL Everest Elite 300 Headband Cushion Replacement: passo 3, imagem 1 %32
    • Slide down the "Elite 300" tab.
    • Repeat on both sides.
  4. JBL Everest Elite 300 Headband Cushion Replacement: passo 4, imagem 1 %32 JBL Everest Elite 300 Headband Cushion Replacement: passo 4, imagem 2 %32
    • Use a SIM tool to push pin fully through and out.
    • Repeat on the other side.
  5. JBL Everest Elite 300 Headband Cushion Replacement: passo 5, imagem 1 %32 JBL Everest Elite 300 Headband Cushion Replacement: passo 5, imagem 2 %32
    • Go along the edges with the pick, and pull up, taking off the band.
  6. JBL Everest Elite 300 Headband Cushion Replacement: passo 6, imagem 1 %32 JBL Everest Elite 300 Headband Cushion Replacement: passo 6, imagem 2 %32 JBL Everest Elite 300 Headband Cushion Replacement: passo 6, imagem 3 %32
    • After fully taking off the band, you are now ready to insert in the new band.
    • When placing in the new headband, line up the holes as shown in image 2.
    • The headband is difficult to replace, however after lining up the holes, the headband will snap into place. Push into the plastic and push away from you. A click will happen indicating it attatching.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 74
