Ir para o conteúdo principal
JBL Clip 4 Battery Replacement
O que você precisa
  1. JBL Clip 4 Battery Replacement, Front Grill: passo 1, imagem 1 %32
    • Get a tool to pry the front grill off, ideally using one of the iFixit tools. This is required as the front grill is glued onto the device.
    Pergunte ao FixBot
    Comentar
  2. JBL Clip 4 Battery Replacement: passo 2, imagem 1 %32
    • Now you just need to pry it off using your chosen tool and it should come off easily leaving you with the front grill separated from the device. Your device should look like this after removing the front grill.
    Pergunte ao FixBot
    Comentar
  3. JBL Clip 4 Battery Replacement, Back Housing: passo 3, imagem 1 %32
    • First, you must unscrew the 5 Phillip head screws (6mm) around the edge of the device.
    Pergunte ao FixBot
    Comentar
  4. JBL Clip 4 Battery Replacement: passo 4, imagem 1 %32
    • Now with the unscrewed front and back housing, you should see some cables that connect between the two. Simply unplug these cables and the back housing will come apart from the front.
    Pergunte ao FixBot
    Comentar
  5. JBL Clip 4 Battery Replacement, Battery: passo 5, imagem 1 %32
    • The battery connects into the motherboard, and it is inside the black box shaped part that has a cable connecting into the motherboard. You must disconnect the cable connecting the battery to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. JBL Clip 4 Battery Replacement: passo 6, imagem 1 %32
    • Now all you need to do is pull the battery out of the case its in and you have successfully disconnected the battery from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Trey Adao
Membro desde: 03/06/26
593 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 38
Ao todo: 66
