Ir para o conteúdo principal
JBL Clip 3 Speaker Housing Replacement
O que você precisa
  1. JBL Clip 3 Speaker Housing Replacement, Speaker Grill: passo 1, imagem 1 %32 JBL Clip 3 Speaker Housing Replacement, Speaker Grill: passo 1, imagem 2 %32
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Speaker Housing Replacement, Speaker Housing: passo 2, imagem 1 %32 JBL Clip 3 Speaker Housing Replacement, Speaker Housing: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Speaker Housing Replacement: passo 3, imagem 1 %32
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Speaker Housing Replacement: passo 4, imagem 1 %32 JBL Clip 3 Speaker Housing Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Kyle Montague
Membro desde: 03/28/22
262 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-5, Petersen Spring 2022 Membro de UMass Dartmouth, Team 1-5, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 18
Duração total: 1,567
