Ir para o conteúdo principal
JBL Clip 3 Carabiner Clip Replacement
O que você precisa
  1. JBL Clip 3 Carabiner Clip Replacement, Speaker Grill: passo 1, imagem 1 %32 JBL Clip 3 Carabiner Clip Replacement, Speaker Grill: passo 1, imagem 2 %32
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Carabiner Clip Replacement, Speaker Housing: passo 2, imagem 1 %32 JBL Clip 3 Carabiner Clip Replacement, Speaker Housing: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Carabiner Clip Replacement: passo 3, imagem 1 %32
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Carabiner Clip Replacement: passo 4, imagem 1 %32 JBL Clip 3 Carabiner Clip Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Carabiner Clip Replacement, Carabiner Clip: passo 5, imagem 1 %32 JBL Clip 3 Carabiner Clip Replacement, Carabiner Clip: passo 5, imagem 2 %32
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler Molden
Membro desde: 03/28/22
465 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-5, Petersen Spring 2022 Membro de UMass Dartmouth, Team 1-5, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 160
Duração total: 3,637
