Introdução
The Clip 3 is IPX7 waterproof and offers up to 10 hours of playtime, powered by a 1000mAh rechargeable Li-ion battery. If the battery is not charging or holding adequate charge, the battery may require replacement.
This guide will show you the step by step process of replacing a speaker battery for a JBL Clip 3. The process won’t be too difficult, requiring no special skills. Make sure to be careful when removing parts on this device, because they can be fragile.
O que você precisa
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
Ferramenta utilizada neste passo:Tweezers$4.99
Use a pair of tweezers to lift the two cable connectors from their motherboard sockets.
5 outras pessoas executaram este guia.
5Comentários do guia
What can I use to create a new waterproof seal?
Is this the same process as for the JBL Clip 4?
