Ir para o conteúdo principal
JBL Clip 2 Speaker Replacement
O que você precisa
  1. JBL Clip 2 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: passo 2, imagem 1 %32
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: passo 3, imagem 1 %32
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: passo 4, imagem 1 %32
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
Conclusão
4 outras pessoas executaram este guia.
Michael Hong
Membro desde: 02/01/17
1.014 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team 2-2, Rose Winter 2017 Membro de UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
Membros da 4
Autoria de 7 guias
6 comentários
If no parts are required what are you replacing the speaker with?
Tom - Responder
Tom is right you know!
edward felix - Responder
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - Responder
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - Responder
Hi, where I can buy the speaker please? Thank you.
Govan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 75
Duração total: 6,350
