Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Removing the motherboard will allow access to most of the internal components.
O que você precisa
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
7 outras pessoas executaram este guia.
14 comentários
Hello I have 3 jbl speakers I bought that work only if plugged to the wall and aux cable... other than that it doesn't work at all .. Bluetooth or even the buttons don't function
had same issue. fixed it by reconnecting the cable that conncts LEDs/ buttons
i have the same problem
hello can i ask if how many pins in the flex for power button i accidentally damage when i fixed it
