Ir para o conteúdo principal
JBL Charge Motherboard Replacement
O que você precisa
  1. JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: passo 1, imagem 1 %32 JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: passo 1, imagem 2 %32 JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: passo 1, imagem 3 %32
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Motherboard Replacement: passo 2, imagem 1 %32 JBL Charge Motherboard Replacement: passo 2, imagem 2 %32
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Motherboard Replacement: passo 3, imagem 1 %32 JBL Charge Motherboard Replacement: passo 3, imagem 2 %32
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
    This is NOT liquid Electrical tape! I recommend using 3M adhesive silicone. If you are doing this repair then you can find the 3m adhesive silicone at automotive stores. Liquid tape hardens and 3M adhesive remains mailable vs the rock hardening effect of liquid tape.
    Liz Ramirez - Responder
  4. JBL Charge Motherboard Replacement: passo 4, imagem 1 %32 JBL Charge Motherboard Replacement: passo 4, imagem 2 %32
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Motherboard Replacement: passo 5, imagem 1 %32 JBL Charge Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
    The two screws on the right side (side with the USB port) are too long to extract with the iFixit screwdriver in the basic kit. I needed to use a regular thin PH2 screwdriver to get them out.
    Matthew Poole - Responder
    I had this problem also, whenever putting the screws back in there were still air pockets in the side with smaller screws
    Kamden Runyon - Responder
  6. JBL Charge Motherboard Replacement: passo 6, imagem 1 %32 JBL Charge Motherboard Replacement: passo 6, imagem 2 %32
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Motherboard Replacement: passo 7, imagem 1 %32 JBL Charge Motherboard Replacement: passo 7, imagem 2 %32
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
    Hi , Thanks a lot in my speacker i had broken plastic part which affect clear sound with your guide i open mine seasily and take it out now i have beand new sound which i had before. thanks again.
    kasravihasan - Responder
  8. JBL Charge Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
    There are 2 screws to remove, the other is under the barcode sticker
    Andrew Allman - Responder
    hey bru the scewdriver you useing what do you call it and where can you get the kit
    warren - Responder
  9. JBL Charge Motherboard Replacement: passo 9, imagem 1 %32 JBL Charge Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Motherboard Replacement: passo 10, imagem 1 %32
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Motherboard Replacement: passo 11, imagem 1 %32 JBL Charge Motherboard Replacement: passo 11, imagem 2 %32
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
Conclusão
7 outras pessoas executaram este guia.
Jake Bertholf
Membro desde: 04/01/15
366 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 12-1, Lancaster Spring 2015 Membro de Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
Membros da 5
Autoria de 11 guias
14 comentários
Hello I have 3 jbl speakers I bought that work only if plugged to the wall and aux cable... other than that it doesn't work at all .. Bluetooth or even the buttons don't function
hector - Responder
had same issue. fixed it by reconnecting the cable that conncts LEDs/ buttons
nyancatsarecute -
i have the same problem
Denny Berroa - Responder
Hello, mine doesn't emit any sound, bluetooth is connected, buttons are working, could it be that some audio cable inside is disconnected?
giubo - Responder
hello can i ask if how many pins in the flex for power button i accidentally damage when i fixed it
djcriztorey - Responder
Hello, I have the JBL Charge 2+ and the screws are not at the same places. I'm afraid :(
tmaxer - Responder
Do You have a SD cart slot there?
Marcin -
How much does the motherboard cost.
i have a pulse 2. Please tell me
arvind raj - Responder
I have two jbl charger 3 but doesnt Connect it for wifi, could be the problem.
chejotorres99 - Responder
Where can I get the ribbon cable …mine is broken
jibon jyoti gogoi - Responder
I think I may have gotten the buttons on top, volume & power, wet from my wet hand. After that it wouldn’t power on & off properly and would not connect to bluetooth. The power button will flash blue, and then red, and any combination of the 2, but doesn’t function properly. Won’t stay blue and doesn’t stay solid blue.
Do you think I damaged the mother board? I did remove the mother board as instructed, but I really don’t want to buy one unless I am reasonably sure that is what is up with it.
rockaf - Responder
i want new mother board
Vikash jacks - Responder
i want new mother board can u plz give me your number
I can play music but all the buttons of my JBL Flip6 aren’t working I can just turn on and turn off my speaker I even cannot pair to another device how can I fix it?🙏🙏
lowesley23 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 72
Duração total: 29,998
