Ir para o conteúdo principal
JBL Charge 5 Fabric Case Replacement
O que você precisa
  1. JBL Charge 5 Fabric Case Replacement, Fabric Case: passo 1, imagem 1 %32 JBL Charge 5 Fabric Case Replacement, Fabric Case: passo 1, imagem 2 %32 JBL Charge 5 Fabric Case Replacement, Fabric Case: passo 1, imagem 3 %32
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Fabric Case Replacement: passo 2, imagem 1 %32 JBL Charge 5 Fabric Case Replacement: passo 2, imagem 2 %32 JBL Charge 5 Fabric Case Replacement: passo 2, imagem 3 %32
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Fabric Case Replacement: passo 3, imagem 1 %32 JBL Charge 5 Fabric Case Replacement: passo 3, imagem 2 %32 JBL Charge 5 Fabric Case Replacement: passo 3, imagem 3 %32
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
Conclusão
3Comentários do guia
Dónde puedo encontrar a la venta esos reemplazos
Jose “Joseso” Hernandez - Responder
Where do I find the replacement part?
Peyton Orlowsky - Responder
아니 어디서 구하냐고, 일안하네?
J_ Minhyung - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 54
Últimos 30 dias: 240
Ao todo: 3,426
