Ir para o conteúdo principal
JBL Charge 4 Passive Bass Radiators Replacement
O que você precisa
  1. JBL Charge 4 Passive Bass Radiators Replacement, Speaker Grill: passo 1, imagem 1 %32
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Passive Bass Radiators Replacement: passo 2, imagem 1 %32 JBL Charge 4 Passive Bass Radiators Replacement: passo 2, imagem 2 %32
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Passive Bass Radiators Replacement: passo 3, imagem 1 %32
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: passo 4, imagem 1 %32 JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: passo 4, imagem 2 %32
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Passive Bass Radiators Replacement: passo 5, imagem 1 %32 JBL Charge 4 Passive Bass Radiators Replacement: passo 5, imagem 2 %32
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
Conclusão
9 outras pessoas executaram este guia.
Zachary Colwell
Membro desde: 01/24/19
1.914 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G1, White Winter 2019 Membro de Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
Membros da 4
Autoria de 26 guias
5 comentários
Exactly where are supposed to get parts for this, do you suppose !?
Yash Bhushan - Responder
It says it on the top of the introduction
Jacob Galeano Garcia -
Hi do you hany any suggestion on where to buy the passive radiators?
Epolu Isaac Tushabe - Responder
Were can i get the main cover from can you help please and the subwoofers
Nate Millette - Responder
Yo tengo la charge 4 y se me rompió uno de los radiadores lo que yo quisiera saber si se pueden arreglar o lo tengo que cambiar por otro
Reynaldo Ronquillo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 67
Duração total: 6,848
