Ir para o conteúdo principal
JBL Charge 3 Passive Radiators Replacement
O que você precisa
  1. JBL Charge 3 Passive Radiators Replacement, Passive Radiators: passo 1, imagem 1 %32 JBL Charge 3 Passive Radiators Replacement, Passive Radiators: passo 1, imagem 2 %32 JBL Charge 3 Passive Radiators Replacement, Passive Radiators: passo 1, imagem 3 %32
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
  2. JBL Charge 3 Passive Radiators Replacement: passo 2, imagem 1 %32 JBL Charge 3 Passive Radiators Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tools underneath both tabs.
  3. JBL Charge 3 Passive Radiators Replacement: passo 3, imagem 1 %32
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
  4. JBL Charge 3 Passive Radiators Replacement: passo 4, imagem 1 %32 JBL Charge 3 Passive Radiators Replacement: passo 4, imagem 2 %32
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
Conclusão
5 outras pessoas executaram este guia.
Jack Ng
Membro desde: 10/08/18
2.168 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Membro de Cal Poly, Team S1-G6, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G6
Membros da 4
Autoria de 27 guias
4 comentários
i have a different model of the charge 3 it doesnt have screws but its hard to take out
Water Bass Tester (Water BT) - Responder
mine has screws and was also hard to pull with one hand
Carbon cookie -
Ich finde den Passivenstrahler nicht als Ersatzteil im Internet. Kann wer da helfen?
Sebastix01 _ - Responder
I have two of the same without screws, the process is precisely the same. Just need to do it a little bit harder
Francisco Sarmento - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 40
Últimos 30 dias: 144
Duração total: 14,440
