Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Your battery may need to be replaced if it doesn't hold a charge or is not charging at all. The JBL Charge 3 has a 6000mAH battery.
O que você precisa
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
Remove the two 8mm Phillips #1 screws from the tabs.
NOTE: There may be only one screw.
Remove the six 8mm Phillips #1 screws from the outer battery cover.
Peel the outer battery cover away from the speaker housing.
132 outras pessoas executaram este guia.
32 comentários
you legend. thank you so much! i was worried it was a seal unit!
Super Anleitung! Hat der Akkutausch hat problemlos funktioniert!
Great Guide! Where can I get the foamy coating of the battery’s wires? Or what is the proper term?
I saw one on youtube taking the one from the old battery and putting it on the new one
