Ir para o conteúdo principal
JBL Charge 2 Plus Button Replacement
O que você precisa
  1. JBL Charge 2 Plus Button Replacement, Button: passo 1, imagem 1 %32 JBL Charge 2 Plus Button Replacement, Button: passo 1, imagem 2 %32
    • Pry open the button pad with a spudger.
  2. JBL Charge 2 Plus Button Replacement: passo 2, imagem 1 %32 JBL Charge 2 Plus Button Replacement: passo 2, imagem 2 %32
    • Unscrew the 2 screws that hold the circuit board in place.
  3. JBL Charge 2 Plus Button Replacement: passo 3, imagem 1 %32 JBL Charge 2 Plus Button Replacement: passo 3, imagem 2 %32
    • Pry open the circuit board, starting from the two ends.
    • Remove the circuit board.
    • Do not use a lot of force when prying
Conclusão
11 outras pessoas executaram este guia.
Pochun Chang
Membro desde: 10/15/15
311 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-1, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
Membros da 4
Autoria de 12 guias
5 comentários
Where can I get the circuit board to replace mine in my jbl charge 2 plus?
Cindy Knight - Responder
My charger wasn't working when I first bought it so I bought another charger and that didn't work, why wont it charge and why does the battery shut off after 30 seconds l, give me a new battery
Tim - Responder
my jbl charge2plus have no working power switch &
MD NASIM MOLLA - Responder
Where do you order a new circut board?
Cody Hayden - Responder
¿Dónde puedo obtener la placa de circuito para reemplazar la mía en mi jbl charge 2 plus?
rafael meraz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 28
Duração total: 17,305
