Ir para o conteúdo principal
JBL Charge 2 Plus Bottom USB Ports and Aux Port Replacement
O que você precisa
  1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement, Bottom usb ports and  aux port: passo 1, imagem 1 %32
    • Flip the device so the bottom is facing you.
    • Remove the bottom pad with a nylon or metal spudger.
  2. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: passo 2, imagem 1 %32 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: passo 2, imagem 2 %32
    • Remove the 4 screws that hold the white cover.
  3. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: passo 3, imagem 1 %32
    • Slide under the cover and remove it.
  4. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: passo 4, imagem 1 %32 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: passo 4, imagem 2 %32
    • Remove the one screw holding the circuit board.
  5. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: passo 5, imagem 1 %32
    • Pry the board with the plastic opening tool.
  6. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: passo 6, imagem 1 %32 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: passo 6, imagem 2 %32
    • Slide the ribbon gently out of the connector.
Conclusão
17 outras pessoas executaram este guia.
John Reynolds
Membro desde: 10/16/15
3.134 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 4-1, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
Membros da 4
Autoria de 12 guias
15 comentários
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Clash Ofclans - Responder
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
egyusza - Responder
I think it is not normal, if you can find it please contact me! Thanks
I also need to replace my usb connector, has anyone found out where to get one?
Rick - Responder
need the micro-usb aswell
hellgrenmicke - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 67
Duração total: 26,815
