Ir para o conteúdo principal
JBL Charge 2 Plus Battery Replacement
O que você precisa
  1. JBL Charge 2 Plus Battery Replacement, Passive Radiators: passo 1, imagem 1 %32 JBL Charge 2 Plus Battery Replacement, Passive Radiators: passo 1, imagem 2 %32
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
  2. JBL Charge 2 Plus Battery Replacement: passo 2, imagem 1 %32 JBL Charge 2 Plus Battery Replacement: passo 2, imagem 2 %32 JBL Charge 2 Plus Battery Replacement: passo 2, imagem 3 %32
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
  3. JBL Charge 2 Plus Battery Replacement: passo 3, imagem 1 %32 JBL Charge 2 Plus Battery Replacement: passo 3, imagem 2 %32
    • Remove the four screws that hold the passive radiator in place
  4. JBL Charge 2 Plus Battery Replacement: passo 4, imagem 1 %32
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Battery Replacement: passo 5, imagem 1 %32 JBL Charge 2 Plus Battery Replacement: passo 5, imagem 2 %32 JBL Charge 2 Plus Battery Replacement: passo 5, imagem 3 %32
    • Repeat Step 2, 3 and 4 for the other passive radiator.
  6. JBL Charge 2 Plus Battery Replacement, Battery: passo 6, imagem 1 %32 JBL Charge 2 Plus Battery Replacement, Battery: passo 6, imagem 2 %32
    • Remove the battery wire from the circuit board by pulling it out gently on the side closest to the LCD light.
  7. JBL Charge 2 Plus Battery Replacement: passo 7, imagem 1 %32
    • Remove the 6 screws that hold the white cover in place.
  8. JBL Charge 2 Plus Battery Replacement: passo 8, imagem 1 %32 JBL Charge 2 Plus Battery Replacement: passo 8, imagem 2 %32
    • Use the plastic opening tool to remove the battery.
Conclusão
72 outras pessoas executaram este guia.
John Reynolds
Membro desde: 10/16/15
3.134 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 4-1, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
Membros da 4
Autoria de 12 guias
37 comentários
Great guide but where to source a battery for a JBL charge 2.
Mine failed, complained to Harman and they sent a new one and didn't want the old one so have a spare I'd like to get working.
Thanks in advance
Rob grist - Responder
Had my speaker for a month. It won't charge. Why did it only last a month and I have to get a new one? I'm not satisfied with the speaker for the price that I paid.
Jeanette dagastine - Responder
When I charge my jbl the light in tge power button turns on but when I press it the device does not respond. Please help me...
Tibetan Stoner - Responder
Try disconnecting the battery and plugging it in again.
MarelyOscar -
I just had the same problem, the on/off led got stuck and couldn't get any sound or operation from any button. After different attempts a simultaneous pressing of the Phone together with the - and the + button brought my Charge2 to life again.
Javier G. Valdivia -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 87
Últimos 30 dias: 399
Duração total: 132,085
