Ir para o conteúdo principal
Ion Air Pro Record and Stop Switch Replacement
O que você precisa
  1. Ion Air Pro Record and Stop Switch Replacement, Record and Stop Switch: passo 1, imagem 1 %32
    • Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
  2. Ion Air Pro Record and Stop Switch Replacement: passo 2, imagem 1 %32 Ion Air Pro Record and Stop Switch Replacement: passo 2, imagem 2 %32
    • Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
  3. Ion Air Pro Record and Stop Switch Replacement: passo 3, imagem 1 %32
    • Remove black aluminum casing as shown.
  4. Ion Air Pro Record and Stop Switch Replacement: passo 4, imagem 1 %32
    • Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
  5. Ion Air Pro Record and Stop Switch Replacement: passo 5, imagem 1 %32
    • Remove the record/stop switch. You are then able to replace the switch.
    • Be careful to not misplace the power button and spring that will no longer be secured when the switch is removed.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UW Stout, Team S6-G2, Ogden Fall 2018 Membro de UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 392
