Ir para o conteúdo principal
Iomega Z100S2 Disk Reader Replacement
O que você precisa
  1. Iomega Z100S2 Disk Reader Replacement, Case: passo 1, imagem 1 %32 Iomega Z100S2 Disk Reader Replacement, Case: passo 1, imagem 2 %32
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Disk Reader Replacement: passo 2, imagem 1 %32
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Disk Reader Replacement: passo 3, imagem 1 %32
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Disk Reader Replacement: passo 4, imagem 1 %32 Iomega Z100S2 Disk Reader Replacement: passo 4, imagem 2 %32
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Disk Reader Replacement: passo 5, imagem 1 %32 Iomega Z100S2 Disk Reader Replacement: passo 5, imagem 2 %32
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
  6. Iomega Z100S2 Disk Reader Replacement, Disk Reader: passo 6, imagem 1 %32 Iomega Z100S2 Disk Reader Replacement, Disk Reader: passo 6, imagem 2 %32
    • Unhook the two springs from the front plastic hooks.
    • The black side rails of the reader should easily slide forward and off.
  7. Iomega Z100S2 Disk Reader Replacement: passo 7, imagem 1 %32
    • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • The tab does not come completely out, it only slides up slightly, so don't rip it out!
  8. Iomega Z100S2 Disk Reader Replacement: passo 8, imagem 1 %32 Iomega Z100S2 Disk Reader Replacement: passo 8, imagem 2 %32
    • Grab the reader by its sides and gently pull it upward.
    • There are two wires still connected to the bottom of the reader that haven't been detached.
  9. Iomega Z100S2 Disk Reader Replacement: passo 9, imagem 1 %32
    • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
  10. Iomega Z100S2 Disk Reader Replacement: passo 10, imagem 1 %32 Iomega Z100S2 Disk Reader Replacement: passo 10, imagem 2 %32
    • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
  11. Iomega Z100S2 Disk Reader Replacement: passo 11, imagem 1 %32
    • Lift the reader up and out from the device.
Conclusão
5 outras pessoas executaram este guia.
Ezery Kennedy
Membro desde: 10/05/10
288 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-53, Amido Fall 2010 Membro de Cal Poly, Team 7-53, Amido Fall 2010
CPSU-AMIDO-F10S7G53
Membros da 4
Autoria de 6 guias
2 comentários
Great guide exactly what I was looking for.
Jim Schmidt - Responder
Zip disks were awesome, and they still are they fit that niche between needing something small in capacity but not large enough for a USB flash drive.
Trevor Rawlinson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 6,094
