Ir para o conteúdo principal
Intertek 20006 Fan Replacement
O que você precisa
  1. Intertek 20006 Fan Replacement, Fan: passo 1, imagem 1 %32 Intertek 20006 Fan Replacement, Fan: passo 1, imagem 2 %32
    • Turn off the air humidifier using the 0/1 switch at the bottom edge of back side.
    • Hold the top-back of the air humidifier and remove the upper part from the lower part.
    • Remove water from the water chamber and wipe it.
  2. Intertek 20006 Fan Replacement: passo 2, imagem 1 %32 Intertek 20006 Fan Replacement: passo 2, imagem 2 %32 Intertek 20006 Fan Replacement: passo 2, imagem 3 %32
    • Flip the humidifier so that the bottom is facing upwards.
    • Use a Phillips # 2 screwdriver to remove four 13 mm screws from the bottom cover hole.
    • Remove the bottom cover to access the fan and other parts of the humidifier.
  3. Intertek 20006 Fan Replacement: passo 3, imagem 1 %32 Intertek 20006 Fan Replacement: passo 3, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove four 30 mm screws from the fan.
    • Remove the fan from its place and keep it close to its power connector.
  4. Intertek 20006 Fan Replacement: passo 4, imagem 1 %32 Intertek 20006 Fan Replacement: passo 4, imagem 2 %32
    • Using a spudger, straighten all three metal latches.
    • Hold both edges of the metal cover with your finger and pull upward to take it out from its position.
    • Metal cover edges are very sharp. Watch your finger when holding the metal cover.
  5. Intertek 20006 Fan Replacement: passo 5, imagem 1 %32 Intertek 20006 Fan Replacement: passo 5, imagem 2 %32 Intertek 20006 Fan Replacement: passo 5, imagem 3 %32
    • Pull out the power connector of the fan from its port.
    • Use a wire cutter to cut the tie rope around the wires.
    • When cutting the tie rope, take care to avoid cutting any cables.
    • Remove the fan from the humidifier.
    • Plug in the new fan's power connector.
    • Tie all cables together using a twist tie.
  6. Intertek 20006 Fan Replacement: passo 6, imagem 1 %32 Intertek 20006 Fan Replacement: passo 6, imagem 2 %32 Intertek 20006 Fan Replacement: passo 6, imagem 3 %32
    • Attach the metal cover where it was before.
    • Bend the latches halfway down using a spudger to secure the metal cover.
  7. Intertek 20006 Fan Replacement: passo 7, imagem 1 %32
    • Secure the new fan with the four 30 mm screws using a Phillips #2 screwdriver.
  8. Intertek 20006 Fan Replacement: passo 8, imagem 1 %32 Intertek 20006 Fan Replacement: passo 8, imagem 2 %32
    • Put the bottom cover back in place.
    • Secure the bottom cover with the four 13 mm screws using a Phillips #2 screwdriver.
    • Flip the humidifier right-side up, and attach the upper part
Linha de Chegada
Uma outra pessoa concluiu este guia.
[deleted]
Membro desde: 05/08/20
184 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 31
Ao todo: 917
