Ir para o conteúdo principal
Interlink VP4550 Laser Replacement
O que você precisa
  1. Interlink VP4550 Laser Replacement, Case: passo 1, imagem 1 %32 Interlink VP4550 Laser Replacement, Case: passo 1, imagem 2 %32 Interlink VP4550 Laser Replacement, Case: passo 1, imagem 3 %32
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Interlink VP4550 Laser Replacement: passo 2, imagem 1 %32 Interlink VP4550 Laser Replacement: passo 2, imagem 2 %32 Interlink VP4550 Laser Replacement: passo 2, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Interlink VP4550 Laser Replacement: passo 3, imagem 1 %32 Interlink VP4550 Laser Replacement: passo 3, imagem 2 %32
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  4. Interlink VP4550 Laser Replacement: passo 4, imagem 1 %32 Interlink VP4550 Laser Replacement: passo 4, imagem 2 %32
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
  5. Interlink VP4550 Laser Replacement, Circuit Board: passo 5, imagem 1 %32
    • Avoid picking up the front of the device as you work so that loose parts will not shift.
    • Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
  6. Interlink VP4550 Laser Replacement: passo 6, imagem 1 %32
    • Slide the circuit board down from the tab located underneath the top of the back half
    • The laser is attached to the circuit board and will slide out of its own housing as you slide out the circuit board.
    • Use tweezers to gently remove it if it doesn't come out.
  7. Interlink VP4550 Laser Replacement, Laser: passo 7, imagem 1 %32
    • Use desoldering braid to remove the red and black wires attached to both the circuit board and the laser bulb.
    • When you are ready to attach the new laser bulb, use a soldering iron to solder the new bulb's wires to the circuit board.
Linha de Chegada
Alayna Bruney
Membro desde: 02/11/14
1 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-1, Buehl Spring 2014 Membro de Ohio State, Team 1-1, Buehl Spring 2014
OSU-BUEHL-S14S1G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 160
