O que você precisa
Turn the phone over to where the battery compartment resides.
Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
Remove battery.
Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
Use desoldering braid to remove the red and black wires attached to both the circuit board and the laser bulb.
When you are ready to attach the new laser bulb, use a soldering iron to solder the new bulb's wires to the circuit board.
Quase terminado!
Linha de Chegada
