Ir para o conteúdo principal
Inter-tel IP 8660 Motherboard Replacement
O que você precisa
  1. Inter-tel IP 8660 Motherboard Replacement, Rear Cover: passo 1, imagem 1 %32
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Motherboard Replacement: passo 2, imagem 1 %32 Inter-tel IP 8660 Motherboard Replacement: passo 2, imagem 2 %32 Inter-tel IP 8660 Motherboard Replacement: passo 2, imagem 3 %32
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Motherboard Replacement: passo 3, imagem 1 %32
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Motherboard Replacement, Internal speaker: passo 4, imagem 1 %32
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Motherboard Replacement: passo 5, imagem 1 %32
    • Lift up the speaker.
  6. Inter-tel IP 8660 Motherboard Replacement, LCD Screen: passo 6, imagem 1 %32 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: passo 6, imagem 2 %32 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: passo 6, imagem 3 %32
    • Lift up the motherboard out of its housing in the front cover of the phone.
    • Set the front cover and button pads aside.
  7. Inter-tel IP 8660 Motherboard Replacement: passo 7, imagem 1 %32 Inter-tel IP 8660 Motherboard Replacement: passo 7, imagem 2 %32 Inter-tel IP 8660 Motherboard Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
    • Note: There are four clips, one at each corner of the LCD screen.
  8. Inter-tel IP 8660 Motherboard Replacement: passo 8, imagem 1 %32
    • Flip the motherboard over so that the LCD screen is facing upward.
  9. Inter-tel IP 8660 Motherboard Replacement: passo 9, imagem 1 %32 Inter-tel IP 8660 Motherboard Replacement: passo 9, imagem 2 %32
    • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
    • This is done using the spudger to lift one side out of its housing.
    • Reposition the spudger to the other side of the black clip and push it flush with the other end.
    • Note: The black clip pushes out of the housing and does not come completely loose.
  10. Inter-tel IP 8660 Motherboard Replacement: passo 10, imagem 1 %32 Inter-tel IP 8660 Motherboard Replacement: passo 10, imagem 2 %32 Inter-tel IP 8660 Motherboard Replacement: passo 10, imagem 3 %32
    • Pull gently on the ribbon cable so that it comes loose from the black clip.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 11-24, Maness Winter 2012 Membro de Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 1,116
