Ir para o conteúdo principal
Inter-tel IP 8660 Button Pad Replacement
O que você precisa
  1. Inter-tel IP 8660 Button Pad Replacement, Rear Cover: passo 1, imagem 1 %32
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Button Pad Replacement: passo 2, imagem 1 %32 Inter-tel IP 8660 Button Pad Replacement: passo 2, imagem 2 %32 Inter-tel IP 8660 Button Pad Replacement: passo 2, imagem 3 %32
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Button Pad Replacement: passo 3, imagem 1 %32
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Button Pad Replacement, Internal speaker: passo 4, imagem 1 %32
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Button Pad Replacement: passo 5, imagem 1 %32
    • Lift up the speaker.
  6. Inter-tel IP 8660 Button Pad Replacement, Button Pad: passo 6, imagem 1 %32
    • Lift up the motherboard and set aside
  7. Inter-tel IP 8660 Button Pad Replacement: passo 7, imagem 1 %32
    • Peel off all rubber button covers.
  8. Inter-tel IP 8660 Button Pad Replacement: passo 8, imagem 1 %32
    • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 11-24, Maness Winter 2012 Membro de Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 762
