Ir para o conteúdo principal
Intel NUC5i7RYH Disassembly
O que você precisa
  1. Intel NUC5i7RYH Disassembly, Lower Lid: passo 1, imagem 1 %32 Intel NUC5i7RYH Disassembly, Lower Lid: passo 1, imagem 2 %32
    • Place the NUC upside down and start by using a Phillips head screw driver to remove the lower screws on the lower case door.
    • These screws are held in with retainers, so they won't fall out when you flip the lid.
  2. Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: passo 2, imagem 1 %32 Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: passo 2, imagem 2 %32 Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: passo 2, imagem 3 %32
    • Lift the door, and keep an eye on the cables that connect to the NUC's motherboard. These cables are the power and data cables for the 2.5" hard drive bay.
    • Carefully unplug the cables from the motherboard, and set the bracket aside.
    • In the last photo, the slot for a blade SSD is marked. This is where you would install the blade SSD, and use a screw to hold it in place.
  3. Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: passo 3, imagem 1 %32 Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: passo 3, imagem 2 %32 Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: passo 3, imagem 3 %32
    • Remove the 4 silver screws that hold the hard drive in the bracket. The metal shield with thermal pad in the red box will come off: this comes in handy if you have a blade SSD installed, as it insulates it from the metal.
    • Carefully slide the 2.5" HDD or SSD out of its case.
  4. Intel NUC5i7RYH Disassembly, RAM Removal: passo 4, imagem 1 %32 Intel NUC5i7RYH Disassembly, RAM Removal: passo 4, imagem 2 %32 Intel NUC5i7RYH Disassembly, RAM Removal: passo 4, imagem 3 %32
    • Removal of RAM on these units is just like on a standard laptop: slightly bend each arm on each side of the chip, and allow it to pop up before sliding it out of the socket.
    • If using two sticks of RAM, repeat this process for the lower stick underneath.
  5. Intel NUC5i7RYH Disassembly, Motherboard Removal: passo 5, imagem 1 %32 Intel NUC5i7RYH Disassembly, Motherboard Removal: passo 5, imagem 2 %32 Intel NUC5i7RYH Disassembly, Motherboard Removal: passo 5, imagem 3 %32
    • The motherboard is held in with two black Phillips head screws, located on the left hand side.
    • Be sure to unplug the antenna cables from the wireless card before removing the motherboard.
    • Grasp the ethernet port, and lift the board out of the case.
  6. Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: passo 6, imagem 1 %32 Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: passo 6, imagem 2 %32 Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: passo 6, imagem 3 %32
    • The motherboard should lift right out of the case.
    • To remove the fan, unscrew the two Phillips head screws holding it in. It can then be unplugged from the motherboard.
  7. Intel NUC5i7RYH Disassembly, Finish!: passo 7, imagem 1 %32
    • This unit is relatively easy to disassemble and reassemble. Good luck!
Conclusão
20 outras pessoas executaram este guia.
Jasen Friedle
Membro desde: 08/25/14
3.821 Reputação
Autoria de 3 guias
15 comentários
Clear description, I used it for NUC7i7RYH, where my cpu was often 100 degrees.
I followed your instruction and cleaned the ventilator and removed dust in the ventilation channels.
Problem fixed, temp is now between 50 and 70 degrees.
rob - Responder
Congrats! Thanks for letting me know, and I’m glad to hear your machine is running cooler!
Jasen Friedle - Responder
Hello, I need an audio jack (port) fro this nuc, can’t find it anywhere, any suggestions?
model 5i5ryh
dave - Responder
hello. I need a replacement audio jack (port) for this nuc, model 5i5ryh, can’t find it anywhere, any suggestions?
dave - Responder
You can try looking on eBay for replacement audio jacks. From what I’m seeing, you could potentially use a universal one and solder a few jumper wires to their corresponding pins and make something work.
Jasen Friedle -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 27
Últimos 7 dias: 145
Últimos 30 dias: 665
Duração total: 50,691
