Ir para o conteúdo principal
Instant Pot Smart-60 Plastic Base Replacement
O que você precisa
  1. Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: passo 1, imagem 1 %32 Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: passo 1, imagem 2 %32
    • Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
  2. Instant Pot Smart-60 Plastic Base Replacement: passo 2, imagem 1 %32
    • Take out the inner pot and place it somewhere out of the way.
  3. Instant Pot Smart-60 Plastic Base Replacement: passo 3, imagem 1 %32
    • Flip the Instant Pot over on its top so that the base is facing upward.
  4. Instant Pot Smart-60 Plastic Base Replacement: passo 4, imagem 1 %32
    • Remove the single 12mm Phillips #2 screw holding the base to the device.
  5. Instant Pot Smart-60 Plastic Base Replacement: passo 5, imagem 1 %32
    • Rotate the base counter-clockwise, then gently lift the base off of the device.
Conclusão
3 outras pessoas executaram este guia.
paola alvarez
Membro desde: 01/24/18
543 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S1-G4, Livingston Winter 2018 Membro de Cal Poly, Team S1-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G4
4 Membros
Autoria de 6 guias
14Comentários do guia
Hi, I would like to know, where can I buy a new plastic base? Thank you
nathaliawed - Responder
Hello where can I buy the plastic base
Maureen - Responder
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
davidghamilton - Responder
Did you ever find out where you can buy this part.
Thank you. Belinda
Belinda Berka - Responder
Do you carry the replacement for this. Thanks
khai01 - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 45
Ao todo: 6,920
