Introdução
The float valve requires its rubber seal to function properly. If this or another part of the valve is missing, it will not be able to function properly and needs to be replaced. This guide will demonstrate how to remove and replace the float valve of your instant pot.
Ferramentas
Não são necessárias ferramentas.
Peças
  1. Open the lid of the Instant Pot.  Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base. Turn the lid upside down to access the float valve.
    • Open the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
    • Turn the lid upside down to access the float valve.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove the silicone cover by grasping it and pulling upward. Push down on the metal part of the float valve to pop it out.
    • Remove the silicone cover by grasping it and pulling upward.
    • Push down on the metal part of the float valve to pop it out.
Conclusão
paola alvarez
489 reputação
4 Guides authored
Equipe
Cal Poly, Team S1-G4, Livingston Winter 2018 Membro de Cal Poly, Team S1-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G4
4 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Todo: 178
