Ir para o conteúdo principal
Instant Pot Smart-60 Disassembly
O que você precisa
  1. Instant Pot Smart-60 Disassembly, Bottom access plate screw: passo 1, imagem 1 %32 Instant Pot Smart-60 Disassembly, Bottom access plate screw: passo 1, imagem 2 %32 Instant Pot Smart-60 Disassembly, Bottom access plate screw: passo 1, imagem 3 %32
    • Insert wisdom here.
    You’ll need a T15 bit
    Terrance Kennedy - Responder
  2. Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: passo 2, imagem 1 %32 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: passo 2, imagem 2 %32 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: passo 2, imagem 3 %32
    • Remove 3x bolts
  3. Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: passo 3, imagem 1 %32 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: passo 3, imagem 2 %32 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: passo 3, imagem 3 %32
  4. Instant Pot Smart-60 Disassembly, Circuit board 1: passo 4, imagem 1 %32 Instant Pot Smart-60 Disassembly, Circuit board 1: passo 4, imagem 2 %32 Instant Pot Smart-60 Disassembly, Circuit board 1: passo 4, imagem 3 %32
    • Black molex connector on top right must come out to remove the outer shell.
    • Red wire spring clips with blue translucent covers I was unable to remove safely, I suggest removing other ends of those wires if you need to remove the heating element plate.
  5. Instant Pot Smart-60 Disassembly, Battery and front panel wires: passo 5, imagem 1 %32 Instant Pot Smart-60 Disassembly, Battery and front panel wires: passo 5, imagem 2 %32 Instant Pot Smart-60 Disassembly, Battery and front panel wires: passo 5, imagem 3 %32
    • I needed small needle nose pliers to pinch and remove wide front panel connector.
    J'aimerais savoir ou je peut trouver la platine électronique principale
    Qui et enpanne/( l'adresse car je n'arrive pas a trouver le fabricant.merci)
    Jean Claude Ballester - Responder
  6. Instant Pot Smart-60 Disassembly, Outer shell ground wire: passo 6, imagem 1 %32 Instant Pot Smart-60 Disassembly, Outer shell ground wire: passo 6, imagem 2 %32 Instant Pot Smart-60 Disassembly, Outer shell ground wire: passo 6, imagem 3 %32
  7. Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: passo 7, imagem 1 %32 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: passo 7, imagem 2 %32 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: passo 7, imagem 3 %32
  8. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: passo 8, imagem 1 %32 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: passo 8, imagem 2 %32 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: passo 8, imagem 3 %32
    • I'm skipping removing heating element and nearby sensors, it's similar to other models. Search for Instant Pot repair videos for instructions.
  9. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: passo 9, imagem 1 %32 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: passo 9, imagem 2 %32 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: passo 9, imagem 3 %32
  10. Instant Pot Smart-60 Disassembly, Outer shell re-assembly: passo 10, imagem 1 %32 Instant Pot Smart-60 Disassembly, Outer shell re-assembly: passo 10, imagem 2 %32
    • Pull lid sensor wire up, re-tape to inside of outer shell.
    • Battery replacement, you should remove the screw and pull the mini circuit board holding the battery before attempting to swap batteries.
    The battery needs to be de-soldered to be removed.
    sputicus - Responder
Conclusão
8 outras pessoas executaram este guia.
Zen1
Membro desde: 03/01/18
392 Reputação
Autoria de 1 guia
3 comentários
If the outer shell is dented but panel is functioning is it safe to operate the instant pot? looks like it moved a bit in the box in shipment, no visible damage to the pot just the to the aluminum shell
Jeff Medlin - Responder
Mine is dented and it should be totally fine. As you said, the pressure vessel is separate from the outer shell, so there are no safety concerns. Just asthetic. I wish there wasn't this gap of air between the pressure vessel and the outer shell, or, I wish the shell was a bit more durable as it's VERY easily dented.
Kuake Ye - Responder
What is the voltage of the component named ZNR091
Yanni Koulandris - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 31
Últimos 30 dias: 129
Ao todo: 8,617
