Ir para o conteúdo principal
Instant Pot IP-DUO80 V2 LED Display Replacement
O que você precisa
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: passo 1, imagem 1 %32 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: passo 1, imagem 2 %32 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: passo 1, imagem 3 %32
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 2, imagem 1 %32 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 2, imagem 2 %32 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 2, imagem 3 %32
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 3, imagem 1 %32 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 3, imagem 2 %32
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 4, imagem 1 %32 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 4, imagem 2 %32
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 5, imagem 1 %32 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 5, imagem 2 %32 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 5, imagem 3 %32
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 6, imagem 1 %32
    • Lift the silver outer shell off of the top black ring.
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 7, imagem 1 %32 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 7, imagem 2 %32 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 7, imagem 3 %32
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
Conclusão
6 outras pessoas executaram este guia.
Kayla Meacham
Membro desde: 01/23/18
634 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G2, Livingston Winter 2018 Membro de Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
Membros da 4
Autoria de 10 guias
2 comentários
Where can I get the replacement for the display?
Starfish Doodle - Responder
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 49
Duração total: 6,869
