Ir para o conteúdo principal
Instant Pot IP-DUO80 V2 Float Valve Replacement
O que você precisa
  1. Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: passo 1, imagem 1 %32 Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: passo 1, imagem 2 %32 Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: passo 1, imagem 3 %32
    • Remove the lid by twisting it counter-clockwise.
  2. Instant Pot IP-DUO80 V2 Float Valve Replacement: passo 2, imagem 1 %32
    • Place the lid upside down on a stable surface.
  3. Instant Pot IP-DUO80 V2 Float Valve Replacement: passo 3, imagem 1 %32 Instant Pot IP-DUO80 V2 Float Valve Replacement: passo 3, imagem 2 %32 Instant Pot IP-DUO80 V2 Float Valve Replacement: passo 3, imagem 3 %32
    • Remove the white rubber cover from the red float valve by pulling it off gently.
    • The red float valve will fall once the white cover is removed.
Conclusão
Kayla Meacham
Membro desde: 01/23/18
634 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G2, Livingston Winter 2018 Membro de Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
Membros da 4
Autoria de 10 guias
3 comentários
On my model, the metal housing broke off, looks like it will need to be welded back together to the lid.
Harry Ethington - Responder
my float valve rubber is missing what can i do???how i can oder this how m gonna fix it kindly answer
ixbah aries - Responder
How do you remove the house that the pin goes into? Mine has corrosion on the pin and inside that housing.
Resist - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 53
Duração total: 5,167
