Introdução
How to replace the float valve on the Instant Pot IP-DUO. This procedure and part is the same for the following models: IP-DUO50, IP-DUO60, and the IP-DUO80.
O que você precisa
3Comentários do guia
On my model, the metal housing broke off, looks like it will need to be welded back together to the lid.
my float valve rubber is missing what can i do???how i can oder this how m gonna fix it kindly answer
How do you remove the house that the pin goes into? Mine has corrosion on the pin and inside that housing.
