Ir para o conteúdo principal
Instant Pot 60 EPC Pressure Sensor Replacement
O que você precisa
  1. Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: passo 1, imagem 1 %32 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: passo 1, imagem 2 %32 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: passo 1, imagem 3 %32
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Pressure Sensor Replacement: passo 2, imagem 1 %32 Instant Pot 60 EPC Pressure Sensor Replacement: passo 2, imagem 2 %32
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Pressure Sensor Replacement: passo 3, imagem 1 %32 Instant Pot 60 EPC Pressure Sensor Replacement: passo 3, imagem 2 %32 Instant Pot 60 EPC Pressure Sensor Replacement: passo 3, imagem 3 %32
    • In order to reach the pressure sensor you'll need to remove the secondary frame.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
    • Locate the sensor. It has been highlighted in the final image.
  4. Instant Pot 60 EPC Pressure Sensor Replacement: passo 4, imagem 1 %32 Instant Pot 60 EPC Pressure Sensor Replacement: passo 4, imagem 2 %32
    • To remove the sensor, unscrew the main screw between the sensor and slide out.
  5. Instant Pot 60 EPC Pressure Sensor Replacement: passo 5, imagem 1 %32 Instant Pot 60 EPC Pressure Sensor Replacement: passo 5, imagem 2 %32 Instant Pot 60 EPC Pressure Sensor Replacement: passo 5, imagem 3 %32
    • To remove the leads connecting the sensor to the motherboard you will need to unclip them.
    • In order to do so, slide the blue covering up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not avaliable then a paperclip or earring should suffice.
  6. Instant Pot 60 EPC Pressure Sensor Replacement: passo 6, imagem 1 %32 Instant Pot 60 EPC Pressure Sensor Replacement: passo 6, imagem 2 %32
    • There will be a secondary lead that is black connecting the sensor the the motherboard.
    • In order to remove that lead just squeeze and pull up.
  7. Instant Pot 60 EPC Pressure Sensor Replacement: passo 7, imagem 1 %32
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
Conclusão
4 outras pessoas executaram este guia.
1Comentário do guia
My pro plus comes with only one sensor. Where can I find it's replacement?
Dr. Khalid S - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 71
Ao todo: 562
