Ir para o conteúdo principal
How to Install macOS High Sierra
O que você precisa
  1. How to Install macOS High Sierra, How to Install macOS High Sierra: passo 1, imagem 1 %32 How to Install macOS High Sierra, How to Install macOS High Sierra: passo 1, imagem 2 %32
    • With the device powered off, disconnect any external hard drives and flash drives.
    • Plug in your macOS High Sierra bootable flash drive.
    • Hold down the [option] or [alt] (⌥) key on the keyboard and power on the device.
    • When you see the boot selection screen as shown, release the [option] key.
    • Use either the keyboard's arrow keys or the mouse to select "Install MacOS High Sierra." Press [enter] or click your selection with the mouse.
  2. How to Install macOS High Sierra: passo 2, imagem 1 %32 How to Install macOS High Sierra: passo 2, imagem 2 %32
    • Your Mac will begin copying the installation files from the flash drive. This may take up to 30 minutes.
    • Depending on the speed of your flash drive, it may look like progress has frozen, but it should resume if you continue to wait.
    • When prompted, select your language and press [enter], or click the arrow button.
  3. How to Install macOS High Sierra: passo 3, imagem 1 %32 How to Install macOS High Sierra: passo 3, imagem 2 %32
    • If you don't need to pre-configure your hard drive, skip to step 5. If you're not sure or if the drive is used, it's a good idea to pre-configure your hard drive.
    • Select "Disk Utility" from the menu and press [enter] or click the continue button.
  4. How to Install macOS High Sierra: passo 4, imagem 1 %32 How to Install macOS High Sierra: passo 4, imagem 2 %32 How to Install macOS High Sierra: passo 4, imagem 3 %32
    • Select your hard drive from the left column in Disk Utility.
    • It is most likely the uninitialized drive.
    • If you have multiple hard drives, make sure you select the correct one as the next step will wipe the selected drive clean.
    • Click the "Erase" button at the top of the window.
    • Choose a name for your drive (you can rename it later). Leave the scheme as GUID Partition Map.
    • If you are installing an SSD, choose the APFS format. If you are installing a mechanical drive or if your device doesn't officially support the newer OS, leave the format as Mac OS Extended (journaled)
    • Click "Erase." When the process completes, click "Done."
    • Exit the Disk Utility by clicking on the red X button on the top left corner of the window.
  5. How to Install macOS High Sierra: passo 5, imagem 1 %32 How to Install macOS High Sierra: passo 5, imagem 2 %32
    • Select "Reinstall macOS" from the menu and press [enter] or click "Continue."
  6. How to Install macOS High Sierra: passo 6, imagem 1 %32 How to Install macOS High Sierra: passo 6, imagem 2 %32 How to Install macOS High Sierra: passo 6, imagem 3 %32
    • Read through the license agreement.
    • Click "Agree" to accept the license agreement.
    • Your Mac will now install macOS High Sierra. Be patient and wait for it to complete.
    • Once the install is complete, the device will restart itself.
Conclusão
High Sierra should now be freshly installed! Enjoy!
620 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
249.876 Reputação
Autoria de 503 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.732 guias
74 comentários
I replace Toshiba MK1231Gal dard disk based on instruction on yutube http://www.youtube.com/watch?feature=pla...!
the problem is that when I try to install osx, I cant format the disk
I got notice input, output error, when try to make a partition or try anything with disk utility
I own MacBook air 1237
Iztok - Responder
Iztok - Responder
yes, me too...did you get it fix? please share how.
jay zee -
Use disk utilities from the Mac OS installer to format the new drive in a Mac format. Then install the Mac OS. New drive won’t show up in the installer until it’s Mac format.
littleduckltd -
DDD in this case
dard disk
Ben Capehart -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 239
Últimos 7 dias: 1,639
Últimos 30 dias: 8,161
Duração total: 1,813,042
